Showing results for tags 'json cache'.
  1. Hi all I log data to a log object through this function in a VD... Sometimes when the data logs comes very close in time it could look like logg data actually disappear. This can be seen here: http://www.incedo.eu/~sjoholmp/Fibaro_Homecenter/Fibaro_potential_cache_issue/logg_object-GUI.png http://www.incedo.eu/~sjoholmp/Fibaro_Homecenter/Fibaro_potential_cache_issue/logg_object.json As you could see the log data row is allocated but the data is never written to the VD... However.... After adding more log data to the log object (In this case I turned the AC power of to my alarm that triggered another log object) I can see that the missing stuff was not actually missing. Now it is magically there. So it seem the HC2 holds the data somewhere in RAM but won't write it out to the log object until the next data comes. Sounds like a bug to me... The missing data that is now there is "15:17:58 User Opening P1 User: Isak" and "15:17:54 P1: Entry Delay" http://www.incedo.eu/~sjoholmp/Fibaro_Homecenter/Fibaro_potential_cache_issue/logg_object-GUI-2.png http://www.incedo.eu/~sjoholmp/Fibaro_Homecenter/Fibaro_potential_cache_issue/logg_object-2.json Any comments or suggestions? Peo
