Showing results for tags 'json lua decode'.
  1. ROBBshop
    Json decode
    Hi all, I am trying to json decode a response of a http command. So far: -I give the command local MyIp = fibaro:getGlobalValue("ApplicationIP") HC2 = Net.FHttp(MyIp,88) response ,status, errorCode = HC2:GET("/output_format=json&setsomeaction=1) I capture the responds: fibaro:debug(response) local response_table = json.decode(response) The responds itself: [DEBUG] 14:48:09: { "u:someactionresponds": { "OK": "OK" } } Now when I try to debug it won't have it. fibaro:debug(response_table.u:someactionresponds['OK']) [ERROR] 14:51:27: line getGlobalValue("MyIp")..."]:12 I want to capture the "OK" to test against. Any help is appreciated
