Showing results for tags 'keypad dimming'.
  1. Hi. I'm looking for a sample on how to increase light of a dimmer when button on keypad (remote) is pressed. Right now I have a fibaro dimmer module and a keypad. Currently I've implemented the scene below to test. The lights are now turned on/off. The keypad sends 12 when button is held down, and 11 when it is released. What I would like to accomplish is to increase the current light value while the button is held down, and off course do the opposite with another button. Any tips is appreciated. Cheers ! --[[ %% properties 100 sceneActivation %% globals --]] -- NodON Configuration -- -- Left Up = 10 -- Left UP press = 12 -- Left UP release = 11 -- Left Down = 30 -- Right Up = 20 -- Right Down = 40 local DeviceID1 = 118 -- Light Spisestue local DeviceID2 = 114 -- Light TV-Stue local ButtonPressed = fibaro:getValue(100, "sceneActivation"); if ( tonumber(ButtonPressed) == 10) then fibaro:call(DeviceID1, "turnOn"); elseif ( tonumber(ButtonPressed) == 30) then fibaro:call(DeviceID1, "turnOff"); elseif ( tonumber(ButtonPressed) == 20) then fibaro:call(DeviceID2, "turnOn"); elseif ( tonumber(ButtonPressed) == 40) then fibaro:call(DeviceID2, "turnOff"); else fibaro:debug(ButtonPressed); end
