Showing results for tags 'label name'.
  1. Hello, I can put data in Virtual device labels with a for loop in LUA code: fibaro:call(63, "setProperty", "ui." .. Labels[n] .. ".value", kwh[n] .. " Kwh") What property (like value) do i use to change the name of these labels? Where can i find this documentation? (it is not in http://myhc2ip/docs) Thanks!
