Showing results for tags 'led bulbs'.
  1. Hi Guys I have an issue with the installation of and FGS212 my problem is i have only a two wire systems means the N is only at the bulb and on the switch, I have only the the L wich is interrupted by the mech switch. I think i did it right i can switch on the light but in that moment the FSG212 did not get power and the relay fell down, i think this is because of the LED i think with a normal bulb it will work. Will, in this case, the bypass will help? Regards Chris
