Showing results for tags 'light switch'.
  1. Hi, Im kinda new to the automation world, I just purchased 3 Logic Home Control Fuga ZHC5010 Light switches and they work perfectly fine with associations. However, I have spent a bit of time trying to get them to function in pairs . The issue is that when i use two or more switches for the same lights (dimmers) they do not trigger each switch state meaning. if the light is ON already and you click on another switch wich state is OFF. you have to click twice to turn OFF the lights "i know small problem" I have tried using the Device Grouping function it works one way however when the slave is triggered it does not affect the state of the master switch. Then i have tried to include each switch in the association this sometimes result in a feedback loop going insane. (our nightbour knocked asking if something was wrong because the entire house looked like a Christmas three.) Is there any way to resolve this issue i just can't think of? Thanks in advance! Simon
  2. Hello Everyone, I 've just installed my TBK HOME (TD-35Z/S) light switch and add it to my Home Center Lite ( 4.170 Ver). The problem is that the device seems to be NOT Configured in the HCL. I 've try several times for reconfiguration but with no luck. Have you ever seen this issue before? Is there anything that i can do in order to have this under configured mode and use this device in my scenes? Thank you in advance,
