Showing results for tags 'lighting control'.
  1. Hi all, Hoping I can get some help. I've got two lights I'm looking to get control of with the right Fibaro modules and my Smartthings hub. First is a straightforward single non-dimmable toggle light switch so I'm guessing the "Single switch 2" module is the one I need for that? The light is an outdoor one with two 9w fluorescent lamps - would there be any issue with controlling a light with 18w total? Second is a double light switch in the hallway. One of the switches on this controls two separate lights in the hallway. The other switch controls lights in the upstairs landing. What I want is control of just the switch which controls the two downstairs lights - is that possible? If so, how and which module would I need? Third is a single toggle switch which controls all the downlights in the living room. The bulbs are all dimmable so what I'd like is the ability to control these lights and dim them from the app. I know I'd need a different switch if I wanted to be able to dim from the switch as well but I don't need that. So do I use the "dimmer 2" module for this? I should point out that all my backboxes are deeper than standard as I deliberately had these installed for the Fibaro modules when the house was renovated. Any help would be much appreciated! TIA!
  2. I am new here and need your imput to setup a wireless home automation systems which include 1) 8 zones of Audio which include ( 2 x Living room, 3 x bedroom, 1 x kitchen, 3 x bathroom. 2) 5 zones of lighting control with dimming 3) 1 unit of window control. I want to be able to use fibaro systems and app to control all. I need help to choose the right lighting, electric curtain track and multi room audio systems to effectively work with Fibaro
