Showing results for tags 'lights blink'.
  1. Hi all, I'm seeking for advice with regards to LUA code and how to make a lamp blinking whenever some criteria is met. Background info: My laundry machine is located in my garage, I don't have a direct view to it and I also don't hear any sound coming from the machine once I'm in my house. I'd like to create a visual signal that informs me once the laundry machine has finished. All my lights in the house are equipped with Fibaro switches and dimmers, so from that point of view there's no limitation. Also the laundry machine is connected thru a wall plug to the power outlet, which gives me the possibility to power-on/off the machine and allowing me to read out the energy consumption. I don't know the LUA code I need to use in order to let a lamp blink... is there anyone who can help? Thanks and best regards, Mark
