Showing results for tags 'lili scenes hc2'.
  1. Hi I tried setting up my dimmer2 and wall plugs with command "lights off" and "lights" on. Works fine. I have a lot of devices, and it takes a long time to edit the voice command on them all. I am thinking there must be a smarter way. Is it possible to make a scene, controlled by a Lili voice command, and include all the devices I want in this scene? Ideally I would want to say "all lights off", and make all living room lights turn off. Or maybe there is a smarter way. Suggestions welcome. Thanks. Haraldo Edit: Actually it didnt work to set the same command on all the devices. When I say "living room lights off", Lili just replies "What device did you mean". She does not understand "all" as an answer, but if I give her a device name it turns off.
