Showing results for tags 'low air pressure'.
  1. I am trying to monitor and get a remote notification for low air pressure. Would this work? Gems Sensors 210076 Kapton Diaphragm OEM Subminiature Pressure Switch with Brass Fitting, 100VA, 20-60 psi Pressure, 1/4" NPT Male, SPST/Normally Open or Closed Circuit? Thank you in advance, Larry
