Showing results for tags 'lua code'.
  1. very little info on setup. Rain delay - i assume when set it works through global values so when yahoo weather senses rain it automatically applies the delay. ?. If not is there some La to enable this?. Adjust water - what does this actually do?. Lua code to setup to be able to extend the control panel to a mobile device.
