Showing results for tags 'lua scene vd'.
  1. Hello, Does any one know if there is an easier way to control the native Fibaro Plug in's from LUA or Graphical scenes? Below procedure works, but is not so transparent and add's a lot of overhead in my HC2 1) install plug in (i.e. samsung TV) 2) make a VD (ID=76) that controls push the buttons of the plug in In each button I run below LUA code with the button name I find with firefox. HC2 = Net.FHttp ("192.168.0.250") HC2:setBasicAuthentication("userxxxx","passwordxxxx") response = HC2:GET("/api/plugins/callUIEvent?deviceID=35&ElementName=POWER_Button&eventType=onReleased") 3) Make a scene (with LUA or graphical) that pushes the button of the VD. Then I run a scene pushing the button. In this example button 7 fibaro:call(76, "pressButton", "7"); -- Samsung TV woonkamer uit rgds Frank
