Showing results for tags 'mh7h-wh thermostat mco mh7h'.
  1. Hello, I have recently bought several MCO Home MH7H-WH thermostats (v.2.9) and after inclusion in HC2 (sw: 4.630) there are no parameters displayed in the Advanced - Configuration area. I have tried removing and re-adding the thermostat then also tried the soft reconfigure. I can see several slave devices for related functions. 1. I'm asking the Fibaro tech support or community if there should be some parameters displayed here or still this MCO thermostats are not yet fully supported like other (ie: Fibaro) products? Nb: Attached is the Template file downloaded from the device if it helps in any way for Fibaro to add support for this template. Also in the manual I have found the following table related to the parameters but I'm not familiar how to manually add them in the device configuration. 2. For example how should I add / configure parameter 3: "Automatic Temperature Difference Reporting"? id-015F-0712-5102-02-09-McoHome Technology Co., Ltd-.zip
