Showing results for tags 'module FGR-222'.
  1. I just bought a Roller Shutter 2 FGR-222 I would like to know if there is a maximum distance to not exceed between the module and the connected switch. In other words can I install the module next to the roller blind motor (and therefore 2m away from the control switch to which it will be of course connected) instead of the usual install of the module just behind the control switch ? Thanks in advance.
