Showing results for tags 'module control'.
  1. I am looking into replacing an older home automation system. The cabling is centralized into a din rail control panel. The controls are push button and via low voltage (24 volt) cabling. I see that I can use din rail mounting for fibaro switches and dimmers, but can I control these via the existing low voltage wiring that I have going into my control panel? It seems to me that as a standard the high voltage L lead is used to control the fibaro switches. My existing low voltage control wiring is not suited for that. Any input or alternative solutions would be welcome and appreciated. Thank you and best regards.
