Showing results for tags 'multisensor battery'.
  1. Hi I have had huge problems for a while where I loose contact with fibaro multi sensors. Now I m a y b e have something. Today I lost another one. I clicked to try connect to it in the HC2 gui. The node was not responsive. I went to the node removed the battery, put it in again. Nothing... Then I changed the battery and it started to work! Now... I have a battery checker scene running giving me alarm every day if battery devices run low. It did not send me any alarm! Yesterday I know the multi sensor worked. And the battery checker said the battery level in it was 62% yesterday. I cannot see a drop from 62% to a dead not over just 12-15 hours. This only applies to the Fibaro multisensors. At earlier problems I did not automatically change battery when it started to die. Most of them still gave light in the eye and the HC2 shows good battery level, but multi sensor did not work properly. I removed them from zwave and re-included them. I have also switched a few batteries. So maybe this was it... To the question... Anyone that have seen battery reporting from these devices that show more battery than is left in the device? I have fully firmware updated multisensors and HC2 4.510 /Peo
