Showing results for tags 'music player'.
  1. Version 1.0.1
    118 downloads
    Here's a virtual device I created to control my Volumio Music Player, which is running on a Rasbperry Pi. Volumio comes with an own built-in ReST API that I use for the this virtual device. You must have your Volumio connected to your local area network (the same as Fibaro HC). After importing the virtual device, set the IP address and the port (default port 80) to point at your Volumio. Offical site of Volumio: www.volumio.org Volumio ReST API documentation: www.volumio.github.io/docs/API/REST_API.html Note: Tested on Fibaro HC2 4.180 Enjoy.
