Showing results for tags 'native function'.
  1. Hi there, I'm a developer but I'm fairly a newbie with LUA language and I'm having some problems undestanding the scope of the variables/functions, or maybe I'm just writing some garbage code... I need your help I want to use the native LUA function "load()" to evaluate a string and let it parse it as LUA code. I'm following LUA 5.2 documentation ( http://www.lua.org/manual/5.2/manual.html#pdf-load ) to use function, but I keep getting this error "attempt to call global "load" (a nil value) and I can't solve it. Here's my chunk of code: And here's the error Btw I'm using load() to make sure mainloop code is called right after button press, and not after 2/3 secs. Hope someone can help me out =) Thank you!
