Showing results for tags 'netatmo valves thermostat'.
  1. Hi all sorry for stupid questions, but I'm totaly newbie in HC2....I've Netatmo Thermostat (already in HC2 added), but it doesn't give me chance to change plans - I've defined some heating plans (via default app), but I can change just Away On/Off and set manually temp in HC2. This is OK? There is no way to change heating plan via HC2? And I've also Netatmo Valves, but I didn't find a module, whatever to control valves (or at least get the actual values) of the valves.... Any help will be nice Thanks, Zdeněk
