Showing results for tags 'no ac'.
  1. Hi All, Hoping someone can provide some insight into this. I have a FGR-222 which I would like to connect to my Garage Roller door Motor. What I currently have is: - Forcedoor FS 1000 door opener. Manual located here. - The unit is directly connected to an AC wall socket and has no wall switch - The manual advices to connect the wall switch to GND & PB points that are on the unit. From my understanding the wall switch will not require AC/Live wire connection. See the attached image. Can I connect the FGR-222 to this unit? If yes, how? Will I need to provide a Live and Neutral to the FGR-222 and connect Q1 and Q2 to PB and GND? and not worry about S1 and S2? Any pointers will be greatly appreciated, Thanks in advance.
