Showing results for tags 'one wallbox'.
  1. Hi, I was assuming that the dimmer2 (FGD-212) had the capability to dim and switch 2 lights seperately..... Looking at the installation and documentation I can only switch one lamp with one module. Not a big issue, I can use the module somewhere else...but question is which dimmer module is capable do to this? It is a single wallbox so no space to install 2 dimmer modules. Was looking at qubino ZMNHBA2 but seems that one is not capable of dimming, only switching. Currently there is a jung 1252ude double dimmer installed with 3 wires...one live, 2 switch wires. Hope somebody knows a solution for this setup with usage of zwave network!
