Showing results for tags 'parameter not saving'.
  1. Hey Guys, first post here so go easy on me! I bought a HC2 the other day and have spent more than a few hours trying to get a basic setup running this weekend! Only trouble is, I can get any parameters to hold in some devices. that being the FGMS001 Motion Sensor and the AEON labs multi sensor. However I have had success in re-parameterising the FGD211 dimmer module however. I guess I knew the AEON labs parts may have some issues, but surely the Fibaro parts should work correctly. Are there any tricks to this I'm missing? Basically I'll enter the advanced tab, modify a parameter and click the save button. Nothing I do seems to get these changes to take, I've tried unselecting the "Use template for Parameters" check button and adding new parameters. Once I do this the only number that will stick is a 0, however I can confirm this isn't the value the sensor is using. (Parameter 6 motion alarm, it's still operating at the 30s interval as opposed to the 0s parameter value) Not sure if this is a sensor compatibility issue or a HC2 issue? Does anyone have any ideas what I could be doing wrong? I'm running the latest version 4.049 btw. Cheers and thanks in advance! Matt
