Showing results for tags 'philio movement sensor'.
  1. Hi, I recently installed a Philio PSP05 Motion sensor on my Fibaro HC2. It worked fine for a while, but suddenly it started reporting movement continuously, even when it's put in a closed box. Normally the sensor would turn red and then fade away, but now it doesn't anymore. Only the tiny led is lit on movement. Any ideas what could be wrong? I'm suspecting a faulty device. It was used outside, maybe moisture? But according to specs outside use is fine ? (parameter 3 = 80; parameter 7 = 22)
