Showing results for tags 'philips hue bulbs hcl gateway'.
  1. Hi there, Is it possible to turning on/off Philips Hue bulbs in scene(blocks) with the HCL Gateway ? If I use the Philips Hue plugin, I only can manualy turn the bulbs on or off. I can't see/select the bulbs in the blocks scene. Regards, Michael Bakker
