Showing results for tags 'port forwarding ziggo ubee'.
  1. Hi I have some issues starting a scene which I start by using my tasker app. The scene works as follows: 1. When I leave my home, my phone will disconnect from my wifi 2. After it is disconnected, a notification will pop-up and asks "Activate or Deactivate your alarm?" 3. When I push the button "activate", my fibaro alarm scene will start and my home alarm is activated. When I start the scene wihtin my personal (wifi) network, its works fine, but when I turn off the wifi connection and change the ip-address to the external ip-address of my Ziggo Ubee modem, it doesn't work anymore. I have tried: - several attempts of port forwarding in de the modem - static IP in HC2 - change DNS in HC2 Someone any idea?
