Showing results for tags 'power level command'.
  1. Hi, I found this in the documentation of one of my devices (TZ36S - Gen5 ) Power level The switch supports the power level command. The power level command allows controllers to set and get the RF transmit power level of a node and test specific links between nodes with specific RF transmit power. Refer to your controller’s instruction, if it supports this command, for more information. This command is typically used by professional installers. Does anybody know how to implement this with lua Thanks
