Showing results for tags 'rain sensor'.
Found 3 results
  1. Hi, I connected a rain sensor to one of the inputs of the smart implant and configured it as a binary input (NO), option "Rain sensor". The sensor does just close when it starts raining and opens again after it stops raining. This status is reflected as such in the web interface of my Home Center Lite by means of an icon with an open or closed umbrella. On the mobile apps however, this status is not reflected at all in the Home Center app, and only partially in the Fibaro app. In the latter I can see there is a rain sensor, but the icon indicating its status is missing. Is this a known issue? Regards, Thomas.
  2. Afternoon all. Awesome weather for this question in the UK at the moment but , Does anyone know of a rain sensor that i could build/attach to my Fibaro HC2. I have a spare universal sensor that I could use but any help on this would be good. I have had a look over the forums and could not find anything for this. I am happy to build one if needed using components from E-Bay, Amazon or anywhere else that sells them.
  3. Installing Irrigation system at our house and will be controlled by HC2 using the Fibaro 1.5kw relays. One thing that I would like to add is a Rain sensor. Are there any z wave compatible Rain sensors that I can use???
