Showing results for tags 'relay switch 2x15kw'.
  1. Hello, At my home i installed a HCL 10x dubble relay switchs 2 motion detectors 1 smoke sensor 6 wallplugs I have a problem with 2 of the relay switches that are doing strange thing. Some times it happens that when i put the lights on 1 of those switches that i can’t turn it of anymore. Then if you look at the dubbel relay switch 1 side turns off and 1 side not I need to push 10 times the on/off switch on the wall to turn the lights off. Verry fustrating. I already changed the dubbel relay switches to new one , no solution same problem… Does anyone have an idee to solve this. Thx
  2. Hello, I've got a problem with the Fibaro Relay switch 2x1,5kw. I would like to se it as an alternate switch in the lobby. So when I arrive home I switch on the light near the entrance, after that I walk through the lobby and I would like to switch off the light on the other side. How can I connect correctly the Fibaro relay switch for this task. Andras
