Showing results for tags 'rgbw analog in'.
  1. Hello, I have connected a pressure 0-10V sensor to Fibaro RGBW controller input 4. I have measured the input with a multimeter on the RGBW device to vary between 1-9 Volt (approx) for min and max pressure. So far so good. Problem is that the display in GUI does not change according to input voltage. The only way I can have the value to change is to press button "Read configuration". Then is the correct input value displayed but remains unchanged until next press of the same button. Parameter 14 is set to 39320 (3 out, one in). Parameter 43 is set to 1 (0,1 Volt change reporting). I have tried manual polling, nothing happens, polling 30 secs, system polling and no polling. nothing happens.... I have read most threads about analog in but most people seems to have problem with the matching of passive/active voltage. This is not my problem, voltage vary OK at input terminal.... Anybody have any idea why the value is not updating. Thanks in advance for your help /Torbjorn
