Showing results for tags 'rgbw sensors vh400 0-3V'.
  1. Hi all, I configured my Fibaro RGBW Module to read 0-10v inputs on all inputs. So set parameter 14 to 0x8888. I have two strange behaviors: without attached sensor, the voltage between GND and I1 is 10.5V. Why? I attached a VH400 Moisture Sensor to I1. The sensor delivers 0-3v depending on moisture. However if I attach the sensor, I measure 3.8V between GND and I1. Touching the sensor increases voltage to about 5.6V. If I measure the voltage of the sensor without Fibaro Module I get 0.1V ( expected ). If I touch it the voltage increases to about 1.8v ( expected ) The power supply delivers 12VDC to the module and the sensor... Can somebody give me a hint on what I'm doing wrong? Is it not possible to use a 0-3V sensor with the RGBW Module? I'm also afraid of destroying my sensors... Sensor: http://www.vegetronix.com/Products/VH400/ Thank you! Marco
