Showing results for tags 'rgbw value'.
  1. Hi All, I' m not sure if you experience the same but in my case (4 pieces of RGBW controller) its property "value" behaves differently if changes to the light are triggered from an APP / webGUI, or using physical switches. If'm I'm changing the light intensity on an app/webGUI the "value" gets adjusted however if I press the physical switch the "value" is untouched - even if the action was performed - i.e. light was turned off! This leads to the situation I cannot perform the scenes based on the "value" parameter.... Is this a feature or a bug? regards
