Showing results for tags 'rs-z'.
  1. Hello, I have 2 problems with Danfoss RS-Z thermostats and would like to know if someone else had the same issues and how to resolve them. They are connected with HCL and have been working without problems for 6 months 1. Z-wave icon on display is shown constantly, set temperature can be changed via buttons but HCL does not register the change. Restarting HCL does not help. Restarting the RS-Z helps but the same issue appear after few minutes. HCL is in range and temperature reading from RS-Z is correct. 2. RS-Z does not respond to any input. Temperature reading is incorrect and buttons do not change the set temperature. Also, setup button does not work and device can not be restored to factory settings. Please advise, Mihalj
