Showing results for tags 'scan sceenes'.
  1. Greeting! I try to get the scene id from a VD. As I like to have less variables to be entered by users, I try to find a way to identify the scene that is required by VD with a clever way. My idea is to get all scenes and filter them by type "type":"com.fibaro.luaScene" After that, I want to call every scene with args from VD and read the Global Variable sceneId CallScene(test) If args are matching, Scene will write on a global variable with a value of the sceneId if args[1] == 'fndScene' then local sceneId=__fibaroSceneId end Suppose this mechanism may work but as it has big blocks of coding, I like to ask if someone has a greater idea or build it and like to share. Thanks!
