Showing results for tags 'scene weather danfoss'.
  1. Hi what am i doing wrong in this scene i am trying to: if the outside temp is below 3 then set danfoss to 28 for one hour and then danfoss to 4 in one hour i did make to scene for this: --[[ %% properties 164 targetLevel 3 Temperature %% globals --]] setTimeout(function() local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(164, "value"); if (( tonumber(fibaro:getValue(164, "targetLevel")) == 4 ) and (os.time() - deviceLastModification0) >= 3600) then delayedCheck0 = true; end local startSource = fibaro:getSourceTrigger(); if ( ( tonumber(fibaro:getValue(3, "Temperature")) < tonumber(3) ) and ( delayedCheck0 == true ) or startSource["type"] == "other" ) then fibaro:call(164, "setTargetLevel", "28"); end end, 3600000) and --[[ %% properties 164 targetLevel %% globals --]] setTimeout(function() local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(164, "value"); if (( tonumber(fibaro:getValue(164, "targetLevel")) == 28 ) and (os.time() - deviceLastModification0) >= 3600) then delayedCheck0 = true; end local startSource = fibaro:getSourceTrigger(); if ( ( delayedCheck0 == true ) or startSource["type"] == "other" ) then fibaro:call(164, "setTargetLevel", "4"); end end, 3600000) regards Elvar Páll www.webcam-iceland.com
