Showing results for tags 'sensative strip'.
  1. I have installed a Sensative Strip Drip to alert me about water leaks. The device works as planned, and was recently triggered. On the HC2 it indicated "breached", and the icon turned red. But I received no push message to my phone! I know I have the push system set up, as I regularly receive messages from other units. Typically, thermostats and temperature measurements, where "possible fire" and "freezing" are indicated when temperatures exceed those limits. I must have missed something to make the Sensative Strip trigger a push message in a similar way. What do I need to do? I have not set up an alarm panel yet. Is that necessary to make such devices with alarm frames trigger push messages or e-mails? And what about third party smoke alarms - do they need to be included in an alarm panel to trigger push messages or other alerts?
