Showing results for tags 'sir 321'.
  1. Hello, Has anyone used the secure SIR 321 with the optional temperature probe attached? When i had the electric switch on SmartThings I was using it to control my hot tub heater. I could set the desired temperature and then ST would turn the switch on/off as the temperature changed. Essentially it's an immersion switch for z-wave. I've added the SIR 321 into fibaro ok, and it works fine as on/off but i can't see how to read the temperature from it. Haven't found any topics relating to this device either surprisingly. Any help appreciated. Thank you Marcus
