Showing results for tags 'string lua'.
  1. I have the following code: local bathroomTemperatuur = tonumber(fibaro:getValue(263, "value")); if bathroomTemperatuur ???????? then fibaro:call(242, "setProperty", "ui.bathtemp.value", " " ..string.format('%.1f',bathroomTemperatuur).. " ℃"); else fibaro:call(242, "setProperty", "ui.bathtemp.value", " " ..string.format('%.f',bathroomTemperatuur).. " ℃"); end I want to accomplish the following idea: if the temp is between 18.1 - 18.9 then 1 digits after comma else If the bathroom temperature is example 18.0 / or 18 then it should show only zero digits after the comma end Any help would be appreciated ? (temperatures are examples, it can be any temperature)
