Showing results for tags 'system time'.
  1. Once upon a time all of use had troubles with system time. But this is long ago - Ithought. I worked on some ideas with heating panel and have to synchronize FGT-001 with it because to work proper. I thought i have solved the issue and suddenly I recognized misbehavior again. While searching with heatpanel, FGT and so on I see that HC2 systemtime differs to MESZ. At the very moment I go to the Configuration Menu systemtime of HC2 corrects its self just by bring up the menu. I use "de.pool.ntp.org" for NTP at location topic. I also recongnized for the first time "This site can't use google maps correctly" , but i don't feel the need to go to location topic much often. Anyone else with system-time issues nowadays?
