Showing results for tags 'thermostat qubino and homecenter 2'.
  1. Hello. I am trying to configure a Qubino flush heat&cool thermostat with a Fibaro HomeCenter 2 and after the devce inclusion, I get the message: I have tried multiple times to delete/exclude/reinclude, reconfigure, soft-reconfigure the device but still get the same message. I know that the device is supposed to work without template, but the thing is that the damn thermostat doesn’t work AT ALL and I am thinking that it might be damaged. It doesn’t show any temperature (although it was included – for like a thousand times- WITH the thermic sensor attached) and if I try to manually add parameters as in the user’s manual, the message is that it doesn’t contain such parameter. Thanks again for your support !
