Showing results for tags 'thermostats heating'.
Found 3 results
  1. Hello, As a beginner I'm trying to understand lua a bit. I have a small lua code that gives the temperature of the room thermostat. Lines 10 and 20 work perfectly, (the mail is sent), but lines 30 and 40 don't work. (load):4: attempt to concatenate a nil value (local 'heatingThermostatSetpoint') The "heatingThermostatSetpoint" is a virtual thermostat, linked to the room thermostat. Does anyone know what to do. Can someone also tell me how I can get different results in 1 email. Thanks.
  2. Hello All, Exist some lua code to integrate Vaillant Erelax Thermostat in Fibaro HC2. Thanks
  3. I'm new to this, so patience. I have 2 SRT321 Secure Thermometer with a Home Centre Lite. The electric heaters will be switched with fibaro relays. The HCL says it has configured the thermostats and I can see that the temperature reading from them shows, but changing the 'set' temperature on the thermostats does not change the HCL set temperature. I want to control the room temp. from the thermostats most of the time, so this is quite critical. HELP!
