Showing results for tags 'tkb home'.
  1. I have : - wall switches and dimmers from TKB HOME. They are TZ65D and TZ 66D. - sockets switches and sockets dimmers from TKB HOME. They are TZ67F and TZ69F. All of them are connected to HC2 with software 4.100 but I observed my problem with earlier software versions as well. If I operate my switches/dimmers from HC2 they are working OK and the HC2 reflects the state of the devices. If I operate my switches manually they are working OK but most of the cases they do no report the current state to HC2. Eg . If I manually switch ON the light, the light is switched ON but HC2 shows it is OFF. That gives me problem with some scenes which should be triggered regarding if the certain light is on or off. I tried to reconfigure z-wave mesh network for some devices but it did not help. Any hint / idea on this ... What is your experience of using TKB Home devices with FIBARO HC2 ?
