Showing results for tags 'touch switch'.
Found 3 results
  1. Can I control WiFi operated touch switch with Fibaro
  2. Hi, Is there any one who have tried to integrate None Z-wave Touch switch with Fibaro controller? If yes then please share your experience.
  3. Hello, I have integration problem, FIBARO Double Switch 2 module with Touch Switch from aliexpress: https://www.aliexpress.com/item/EU-Standard-Touch-Switch-1-Gang-1-Way-White-Crystal-Glass-panel-Light-Switch-Touch-Screen/32725127051.html?spm=a2g0s.9042311.0.0.WJR6Mb Separate Touch Switch working fine, but if I it connecting with FIBARO Double Switch 2 module, when I press light on light just on for 2 secs and off. Maybe someone have same problem and can advice how to solve this problem? Thanks in advice! Giedrius
