Showing results for tags 'trigger variable'.
  1. I'm reprogramming scenes after implementing a second house with a HC2 and trying to follow a different approach. The approach is driven on global variables. If the value is changed the trigger should start. But it doesn't. I have a global variable "avondverlAan" and after changing the value via the admin panel nothing is being triggered. What am I doing wrong? I did the same before with "properties" based on the value of a PIR from Satel which is also a device in HC2. But nothing happens. It only works if an original device from Fibaro is declared at properties, like "5 value", then the scene is triggered as it should be. --[[ %% properties 5 value %% globals avondverlAan --]] local trigger = fibaro:getSourceTrigger() if (trigger['type'] == 'property') then fibaro:debug('Source device = ' .. trigger['deviceID']) elseif (trigger['type'] == 'global') then fibaro:debug('Global variable source = ' .. trigger['name']) elseif (trigger['type'] == 'other') then fibaro:debug('Other source.') end
