Showing results for tags 'two way'.
  1. Hi, Does anyone know if I can I use association to configure two way switching using two separate z wave dimmers? One will be attached to the load while the other will be attached to a dummy load. Plan on using the Qubino 0-10v dimmer. Thanks!
