Showing results for tags 'ui bug'.
  1. So i have this curious device to play with today. SCS317 and its counterpart SSR303 Installing into HC2 v4.1 worked fine, devices seem to cooperate as you'd expect. Once your tempriture is set to 28.5 or above (max 30), it will break the icon on SCS317 (the module with display). Since icon appears to be nearly same for all (just the number changess within icon that is baffling to me. i thought you just ought to be informed.
