Showing results for tags 'vd create rest'.
  1. Hi I can auto create global variables from LUA like this... function createglobalvar(name, value) -- We create a global variable if fibaro:getGlobalValue(name) == nil then local HOST = Net.FHttp("127.0.0.1",11111); local response ,status, err = HOST:POST('/api/globalVariables','{"name":"'..name..'","value":"'..value..'"}'); if DEBUG >= 2 then fibaro:debug('Global variable create status: ' .. status .. ' Error code: ' .. err) end if SYSLOG == 1 then syslogserver('Global variable create status: ' .. status .. ' Error code: ' .. err) end if (tonumber(status) == 201 and tonumber(err)==0) then if DEBUG >= 1 then fibaro:debug('Global variable ' .. name .. ' created') end if SYSLOG == 1 then syslogserver('Global variable ' .. name .. ' created') end if DEBUG >= 3 then fibaro:debug('Response data: ' .. response) end if DEBUG >= 3 and SYSLOG == 1 then syslogserver('Response data: ' .. response) end end else if DEBUG >= 1 then fibaro:debug('Global variable: ' .. name .. ' already exist') end if SYSLOG == 1 then syslogserver('Global variable: ' .. name .. ' already exist') end end end I use that a lot now... But... How can I create a VD? I want to be able to create VDs and VD labels from LUA as well... I simply cannot make it work. And the docs s u c k s. Thanks in advance Peo
