Showing results for tags 'vera lite'.
  1. Hi I am running a HC2 as my zwave controller. But i also has a vera Lite for my 433mhz devices via RFXtrx device. So what is the easiest way for me to fetch status from 433mhz devices. To start with i want to get the current temperature from several tempsensor and the luup variable for that, according to micasaverde, is: luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 5) But where do i go from here? How can i get it into my HC2? I want a virtual device updated every 15 minutes with the current temperature. and can i somehow make my HC2 think that my VD really is a temp sensor?
