Showing results for tags 'water heater'.
  1. Hi I'm new to the HC3 and this is my first post here so please be gentle I'm trying to set up a simple timer to enable a Hot Water Tank Immersion Heater. I've got the ZWave module (a Vesternet high current relay) working and can switch it on and off manually. I have also set up a couple of scenes to turn the immersion on and off for 1 hour and 2 hour periods. Now, I want to switch the immersion heater on at 06:00 and off at 09:00 but can't for the life of me work out how to do it. I have set up the scene shown below but it doesn't work automatically (at the defined times), although it does work if I manually run it Any help very much appreciated
  2. What kind of rely would be best for a water heater. All i want to do is turn it off when i leave home (for vacation) and turn it on when i arrive home. Do you have to get a specific one? do you have to worry about the wattage? Don't want to keep flipping off the breaker every time. Thanks for the help.
