Showing results for tags 'z wave stick'.
  1. Hi guys, So I am wondering whether it is possible to use a 3rd party USB stick such as the Aeotec Gen5 z wave stick to configure the z wave network with Fibaro HC2? The reason I want to do this is in case the HC2 fails, I can connect the a replacement HC2 to the z wave stick which "remembers" the network, so I don't have to manually add the modules to the new HC2. Basically I might end up with some zwave modules that are not connected to a physical switch and are less accessible, making it a pain to re add them if the HC2 fails (which I believe happens quite rarely?) Thanks
