Showing results for tags 'zs5101eu-5 shock sensor'.
  1. I use HC2 v4.100 and my problem is that the Vision shock/vibration sensor ZS5101EU-5 does not update the lastBreached property when breached. I also have the previous version of this sensor and that one works as expected. In this thread: https://forum.fibaro.com/index.php?/topic/21056-vision-zs5101eu-5-glass-shock/ there is some LUA code to catch the breach and it works, but I want to find out if the device has been breached by using the external API. I can catch the breach by checking the alarmLevel and alarmType values but the problem is that as soon as the device leaves breach mode after a few seconds, those values are reset back to default and it's impossible to tell if the device has been in breach mode as lastBreached is not updated. Even when writing scenes directly in LUA would be much easier if lastBreached was updated just as it is on all other devices, because then I could use the same code instead of some special hacks just for this device. Any ideas?
